MECHANICALBROWSERSETTINGS system variable
Mechanical browser options
Sets the default mechanical browser options.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 2047 |
| Default value: | 819 |
| Possible options: |
1: Expressions of constraints 2: Components parameters 4: Expressions of components parameters 8: Sub-components of standard parts 16: Arrays 32: Block and External References 64: Always synchronize selection 128: Keep values list order 256: Highlight objects selected in the browser 512: Asynchronous properties load 1024: Expose all solids |
