MTEXTFIXED system variable
Multiline text fixed
Controls whether the application zooms, rotates and/or pans the view to fit the multiline text to be edited.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 2 |
| Default value: | 2 |
| Possible values: | 0: Do nothing when mtext editor is opened 1: Do nothing when mtext editor is opened 2: Rotate / zoom / pan view to fit multiline text |
