MTFLAGS system variable
Multi-Threading Flags
Bit flags for parallel processing of display and loading.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 4095 |
| Default value: |
3015 |
| Possible options: |
0: No parallel processing 1: Parallelized regeneration of display. 2: Parallelized redraw of display. 4: Parallelized loading of drawings. 8: Parallelized calculation of hidden line removal. 16: Parallelized generation of BIM sections to separate destination files. 32: Parallelized generation of BIM sections to the same destination file. 64: Parallelized computations in Direct Modeling commands and operations. 128: Parallelized computations in Assembly commands and operations. 256: Parallelized computations in Sheet Metal commands and operations. 512: Parallelized interference checking 1024: Delayed XREF loading 2048: Parallelized point cloud operations |
