MULTISELECTANGULARTOLERANCE system variable
BimMultiSelect angular tolerance
Controls the maximum angle between two linear solids axes, for these solids to still be considered parallel.
BricsCAD only
| Type: |
Real |
| Saved in: |
Registry |
| Range: |
0 to 90 |
| Default value: | 3 |
