NEARESTDISTANCE system variable
Nearest Distance
Controls nearest distance dimension between a pair of selected entities. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 15
Default value:
1
Possible options:
1: Show nearest distance dimension
2: Show OX aligned nearest distance dimension
4: Show OY aligned nearest distance dimension
8: Show OZ aligned nearest distance dimension
