NOMUTT system variable
No muttering
Suppresses text in the Command line.
When on, the Command line will stop prompting all the options and actions.
| Type: |
Boolean |
| Saved in: |
Not saved |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t suppress Command line prompts On (1): Suppress Command line prompts |
