OBJECTISOLATIONMODE system variable
Object Isolation Mode
Controls if entities hidden with HIDEOBJECTS or ISOLATEOBJECTS commands remain hidden after a drawing is saved, closed and reopened.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: |
0 |
| Possible options: |
0: Entities are hidden only for the current session, includes interference solids 1: Entities remain hidden between sessions, includes interference solids 2: Entities are hidden only for the current session, does not include interference solids 3: Entities remain hidden between sessions, does not include interference solids |
