OFFSETDIST system variable
Offset distance
Stores the last distance used for the OFFSET command.
Type: |
Real |
Saved in: |
Not saved |
Range: |
-1.0 |
Possible values: |
<0: draws a parallel copy of an entity through a specified point |
Type: |
Real |
Saved in: |
Not saved |
Range: |
-1.0 |
Possible values: |
