OFFSETERASE system variable
Offset erase
Erases the source entity for the OFFSET command.
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
Off |
| Possible values: |
Off (0): Offset erase off On (1): Offset erase on |
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
Off |
| Possible values: |
