OFFSETERASE system variable
Offset erase
Erases the source entity for the OFFSET command.
Type: |
Boolean |
Saved in: |
Registry |
Range: |
Off |
Possible values: |
Off (0): Offset erase off On (1): Offset erase on |
Type: |
Boolean |
Saved in: |
Registry |
Range: |
Off |
Possible values: |
