OLEQUALITY system variable
OLE quality
Controls the default plot quality of OLE entities. When set to Automatically Select (3), the quality level is assigned automatically depending on the entity type (for example, photographs are set to High).
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible values: |
0: Monochrome 1: Low graphics 2: High graphics 3: Automatically Select |
