OSOPTIONS system variable
Entity snap options
Suppresses entity snaps on certain entity types.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 15 |
| Default value: |
7 |
| Possible options: |
0: Entity snaps are enabled on hatched entities, on geometry with negative Z values when using a dynamic UCS, on endpoints of dimension extension lines, and on invisible geometry in shaded and hidden line views. 1: Entity snap ignores hatches 2: Entity snap ignores negative Z values in Dynamic UCS mode 4: Entity snap ignores end points of dimension extension lines 8: Entity snap ignores invisible geometry in shaded and hidden-line views |
