PAPERUPDATE system variable
Paper update
Controls paper size adaption when printers are switched in the Print dialog box.
- If Off: does not update the paper size, preserving the paper size currently selected. If the printer has no close match, the size will be displayed as Previous paper size. On print, your confirmation is required before substitution with default values.
- If On: updates the paper size, using the default paper size of the selected printer.
| Type: | Boolean |
| Saved in: |
Registry |
| Range: | 0 to 1 |
| Default value: | 0 |
| Possible values: | Off (0): Use default paper size of the selected printer On (1): Use configured paper size of the plotter configuration file |
