PARAMETERMATCHMODE system variable
Match Parametric Blocks by parameters
The option is not stored in registry, however for some designated blocks it is known that the individual copy is required for each separate insert.
BricsCAD only
| Type: | Short |
| Saved in: | Not saved |
| Range: | 0 to 2 |
| Default value: | 0 |
| Possible values: | 0: Re-use existing block if insert has same expressions 1: Use separate copy for each block insert 2: Force default behavior for previously separated blocks |
