PARAMETRIZECONNECTIONS system variable
Parametrize Connections
Controls if constraints connect components for the BMCONVERT, BMCONNECT and BMINSERT (SMART insert option) commands.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Don't use constraints 1: Use constraints |
