PBLOCKREFERENCEOPERATIONSVISUALIZATION system variable
Visualize parametric operations on block references
Enables the visualization of the parametric operations' information when hovering the cursor over parametric block references.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Visualization off On (1): Visualization on |
