PDFFRAME system variable
PDF frame
Controls the visibility of PDF underlay frames, if the FRAME system variable is set to Use individual system variables (3).
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible values: |
0: Hide PDF frames 1: Display and plot PDF frames 2: Display but do not plot PDF frames |
