PDFIMAGECOMPRESSION system variable
Image compression
Compresses images to JPEG during PDF export.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: None 1: JPEG |
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: None 1: JPEG |
PDFIMAGECOMPRESSION system variable - BricsCAD Lite & Pro | Bricsys Help Center
