PDFIMPORTAPPLYLINEWEIGHT system variable
Apply lineweight properties
Retains the lineweight properties of imported entities, during PDF import.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Ignore the lineweight properties of the imported entities On (1): Retain the lineweight properties of the imported entities |
