PDFIMPORTASBLOCK system variable
Import as block
Imports PDF files as blocks.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t import PDF files as a block On (1): Import PDF files as a block |
