PDFIMPORTCHARSPACEFACTOR system variable
Inter-character space factor
The multiplier for the width of the space between characters in a word, used during PDF import.
If the distance between the text objects in the string is less than the width of the space taken from the font metric multiplied by this factor, the text objects are combined into one word.
Note: Applies only if PDFIMPORTCOMBINETEXTOBJECTS is turned on.
BricsCAD only
| Type: |
Real |
| Saved in: |
Preference |
| Default value: | 0.6 |
