PDFIMPORTIMAGEPATH system variable
Raster Images Folder
The file path used to save images, during PDF import, absolute or relative.
- If relative, the PDF image path is relative to the folder of the current drawing file.
- If empty, the folder of the current drawing is used, if the drawing has not yet been saved the images will be saved in the same folder as the imported PDF.
| Type: | String |
| Saved in: | Registry |
| Default value: |
PDF Images |
