PDFIMPORTJOINLINEANDARCSEGMENTS system variable
Join line and arc segments
Joins continuous segments into a polyline, where possible, during PDF import.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Range: |
On |
| Possible values: |
Off (0): Don’t join the line and arc segments from imported PDF files On (1): Join the line and arc segments from imported PDF files |
