PDFIMPORTSOLIDFILLS system variable
Solid fills
Ignore or import solid-filled areas during PDF import, if the information is in the PDF. Solid-filled areas include solid-filled hatches, 2D solids, wipeout entities, wide polylines, and triangular arrowheads.
Note: Solid-filled hatches are assigned a 50% transparency.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Ignore solid-filled areas. On (1): Import solid-filled areas. |
