PDFIMPORTSOLIDFILLS system variable
Solid fills
Ignore or import solid-filled areas. If these filled areas were originally exported into PDF format from AutoCAD, the solid areas would include solid-filled hatches, 2D solids, wipeout entities, wide polylines, and triangular arrowheads.
Note: Solid-filled hatches are assigned a 50% transparency so that entities on top or
underneath can be easily seen.
BricsCAD only
| Type: | Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: | Off (0): Ignore solid-filled areas. On (1): Import solid-filled areas. |
