PDFIMPORTUSEIMAGECLIPPING system variable
Clip images
Clips images during a PDF import. The clipped part images becomes transparent.
Note: Applies only if PDFIMPORTUSECLIPPING is on (1).
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
Off |
| Possible values: |
Off (0): Images are not clipped on import On (1): Images are clipped on import |
