PDFIMPORTVECTORGEOMETRY system variable
Vector geometry
Imports vector geometry during PDF import.
If on, linear paths and Beziér curves are imported as polylines within a tolerance. Curves that resemble arcs, circles, and ellipses are also converted. Solid-filled areas are imported as 2D solids or solid-filled hatches. Patterned hatches are imported as many separate entities.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
On |
| Possible values: | Off (0): Don’t import vector geometry On (1): Import vector geometry |
