PDFMERGECONTROL system variable
Pdf Merge Control
Specifies the appearance of lines that cross.
Lines Overwrite Uses the last plotted line to obscure the lines under it. Only the topmost line is visible at the intersection.
Lines Merge Merges the colors of crossing lines.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Default value: | 0 |
| Possible values: | 0: Lines Overwrite 1: Lines Merge |
