PDFNOTIFY system variable
PDF notify
Displays a warning, when a drawing is opened, if there are missing PDFs.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disable PDF notification On (1): Enable PDF notification |
