PDFOPENINVIEWER system variable
Open in viewer
Open result file in system default PDF viewer.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Do not open in PDF viewer.
On (1): Open in PDF viewer.
Related information
  • Plotter configuration
  • Plotter Configuration Editor dialog box
