PDFOSNAP system variable
PDF entity snap
Enables entity snap for PDF underlay files.
Type: |
Boolean |
Saved in: |
Registry |
Default value: |
On |
Possible values: |
Off (0): Disable PDF entity snap On (1): Enable PDF entity snap |
Type: |
Boolean |
Saved in: |
Registry |
Default value: |
On |
Possible values: |
PDFOSNAP system variable - BricsCAD Lite & Pro | Bricsys Help Center
