PDFPAPERSIZEOVERRIDE system variable
PDF papersize override
Enables papersize override for PDF export.
If On, the papersize as defined in the BricsCAD Print settings is overridden. The papersize width and height defined by PDFPAPERWIDTH and PDFPAPERHEIGHT are used instead.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
Off |
| Possible values: | Off (0): Disable papersize override On (1): Enable papersize override |
