PDFPRCEXPORT system variable
PRC Export Mode
PRC mode for the export of PRC 3D data (3D PDFs).
Export as BREP is an experimental mode which may work incorrectly. We recommend using Export as Mesh mode.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible options: |
0: No export 1: Export as BREP (Experimental) 2: Export as Mesh |
