PDFSHXTEXTASGEOMETRY system variable
PDF SHX text as geometry
Converts SHX font text to geometry for PDF exports. This might be necessary if the receiving party does not have the same SHX fonts on their computer.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
Off |
| Possible values: | Off (0): Don’t convert SHX text to geometry On (1): Convert SHX text to geometry |
