PDFSIMPLEGEOMOPTIMIZATION system variable
Pdf simple geometry optimization
Simplifies geometry for PDF exports (merges separate line segments to one polyline and uses Bezier curve control points).
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Disable simple geometry optimization On (1): Enable simple geometry optimization |
