PDFTTFTEXTASGEOMETRY system variable
Pdf TTF text as geometry
Enable the conversion of True Type font text to geometry. This is useful for when the TTF files are covered by a license that prohibits sharing, or you want to make it harder to extract text.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
Off |
| Possible values: | Off (0): Don’t convert TTF text to geometry On (1): Convert TTF text to geometry |
