PDFUSEPLOTSTYLES system variable
Pdf use plotstyles
Enables usage of plotstyles. If On, the plotstyle of the layout controls the color and lineweight in the PDF export.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
On |
| Possible values: | Off (0): Disables usage of plotstyles On (1): Enables usage of plotstyles |
