PDFUSEPLOTSTYLES system variable
Use PDF plotstyles
Enables plotstyles for PDF exports.
If On, the plotstyle of the layout controls the color and lineweight in the PDF export.
BricsCAD only
Type: |
Boolean |
Saved in: |
Preference |
Default value: |
On |
Possible values: |
Off (0): Disables usage of plotstyles On (1): Enables usage of plotstyles |
