PDFZOOMTOEXTENTSMODE system variable
PDF zoom to extents mode
Scales the layout geometry of papersize layouts for PDF exports.
If switched off, uses the scale and papersize from the pagesetup data.
BricsCAD only
| Type: |
 Boolean  |
| Saved in: |
 Preference  |
| Default value: |
 On  |
| Possible values: |
 Off (0): Don’t zoom to extents On (1): Zoom to extents  |
