PDMODE system variable
Point display mode
Controls the display style for point entities.
Type:
Short
Saved in:
Drawing
Range:
0 to 100
Default value:
0
Possible options:
1: none
0: .
2: +
3: x
4: '
32: circle
64: square
Different geometric representations of point entities are provided by values of 0, 2, 3, and 4. You can choose only one options between them. When the value is 1, nothing is shown.
In addition to the geometry drawn by the value 0, 2, 3, or 4, the values ​​32 or 64 specify a shape that can be drawn around it.
