PICKADD system variable
Pick add
Controls how the Shift key selects entities.
| Type: | Boolean |
| Saved in: |
Registry |
| Range: | 0 to 1 |
| Default value: | On |
| Possible values: | Off (0): Press SHIFT to add entities to the current selection On (1): Press SHIFT to remove entities to the current selection |
