PICKDRAG system variable
Pick drag
Controls the window selection behavior used to select multiple entities at the same time.
See also the PICKAUTO system variable.
Type:
Boolean
Saved in:
Registry
Default value:
0
Possible values:
Off (0): Draw selection window with two points
On (1): Draw selection window with click and drag
