PICKDRAG system variable
Pick drag
Controls the window selection behavior used to select multiple entities at the same time.
See also the PICKAUTO system variable.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | 0 |
| Possible values: | Off (0): Draw selection window with two points On (1): Draw selection window with click and drag |
