PICKFIRST system variable
Pick first
Makes it possible to select entities first, then issue a command.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
1 |
| Possible values: |
Off (0): First issue a command, then select entities On (1): First select entities, then issue a command |
