PICKFIRST system variable
Pick first
Allows to select entities first, then issue a command or vice versa.
| Type: | Boolean |
| Saved in: |
Registry |
| Default value: | 1 |
| Possible values: | Off (0): First issue a command, then select entities On (1): First select entities, then issue a command |
