PICTUREEXPORTSCALE system variable
Picture format export scale factor
Controls the output resolution scale for WMF, EMF or BMP exports. Used in commands EXPORT, WMFOUT, COPYCLIP, CUTCLIP and in COM/VBA function AcadDocument. The output view size is the current view size-in pixels, multiplied by this value.
Trouble: Scale values of 10 or more may cause slow system response.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Range: | 0.0 or greater |
| Default value: | 1.0 |
