PLINETYPE system variable
Polyline type
Controls how polylines are created with the PLINE command and if old-format polylines are converted.
It saves disk space and memory by using the optimized format.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
2
Possible values:
0: Old-format polylines are not converted; PLINE creates old-format polylines
1: Old-format polylines are not converted; PLINE creates optimized polylines
2: Old-format polylines are converted; PLINE creates optimized polylines
