PLINETYPE system variable
Polyline type
Specifies the usage of optimized 2D polylines when creating polylines and the conversion of polylines in older drawings. It saves disk space and memory by using the optimized format.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 2 |
| Default value: | 2 |
| Possible values: |
0: Polylines in older drawings are not converted; PLINE creates old-format polylines 1: Polylines in older drawings are not converted; PLINE creates optimized polylines 2: Polylines in older drawings are converted; PLINE creates optimized polylines |
