PLOTCFGPATH system variable
Plotter configuration path
The file path used for the Plotter configuration folders.
Separate file paths with semicolons (;).
When printing a layout, the available paper size settings are controlled by a Plotter Configuration File. The Printer / Plotter configuration list contains all printer drivers installed on your computer. The printer configurations are the files in the folder specified by the PLOTCFGPATH system variable. If the path points to a large folder with many files and subfolders, BricsCAD searches the entire folder tree for appropriate files. This might slow the Print dialog box from opening.
BricsCAD only
| Type: |
String |
| Default value: |
On Windows: %AppData%\Bricsys\BricsCAD\V27x64\en_US\PlotConfig\ |
| Saved in: |
Preference |
