POINTCLOUDADAPTIVEDISPLAY system variable
Toggle adaptive vs. fixed point sizes (Windows & Linux)
Uses adaptive point sizes for point cloud display. If off, uses fixed point sizes.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Use fixed point sizes - all points have the same size 1: Use adaptive point sizes - point sizes are adjusted for a better visual appearance |
